Hi,
Is anyone else out there having similar problems with nanoDVR ? I've tried both the Hauppauge version and the version on their web site and they both do the same.
Basically, I set nanoDVR to use 2800 bitrate, 25fps, Buffers 800+, MPEG1, Coding Speed on 1, Motion Est on 1, High Quality, Capture Audio, Intra B, Fast Audio, Use Overlay. Capturing realtime MPEG1 with a WinTV PCI.
All capturing is superb until about 12 minutes in, and then the picture suddenly turns into squares as if the bitrate has just gone to the lowest setting. Does it use dynamic bitrates ? Or are there settings for the best capture ?
Even the FAQ mentions it
"F: nanoDVR breaks up after a short time. Up to this moment everything works fine. Why?"
But the answer does nothing.
My PC should be up to the task.
Athlon 1.4, 512Mb, Geforce3, Abit KT7a, 60Gb HD ATA100, WinME and WinXP.
Any help most appreciated,
Craig.
Results 1 to 1 of 1
How many minutes per DVD without quality loss?
By cinclodes in forum Newbie / General discussionsReplies: 9Last Post: 16th Dec 2010, 12:57 -
ImgBurn's Layer Breaks
By hech54 in forum Authoring (DVD)Replies: 6Last Post: 28th Oct 2009, 16:10 -
4.6G 120 minute disk giving only 113 minutes at 27% quality Why?
By Emerogork in forum MediaReplies: 22Last Post: 12th Aug 2009, 12:05 -
Easy way to find commercial breaks?
By lj01 in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2008, 14:16 -
avoiding layer breaks
By Dr Who in forum MacReplies: 4Last Post: 30th Oct 2007, 16:48
