Ok, maybe it was already discussed before, but I did not find it.
In the regular Chapter Menu there are 6 buttons:
1. back to Main Menu; 2. Fast Back; 3. Back; 4. Forward; 5. Fast Forward;
and 6. Play.
First five work as they are supposed to work, but the last one (Play) starts Clip from the
very beginning (!?) Is it the way it has to work?
I know that to start playing current chapter I have to press on Picture,
but what about that Play button?
It confuses me.
Maybe it would help if you mentioned the entire name of your authoring program as I am not familiar with the options "Fast Back", "Back", and "Forward". Are they the navigations for the menu? I don't think it's possible to fast forward the movie from the menu. And I'm pretty sure for all authoring programs, the "Play" option is the same as the "Play All" option so it plays from the beginning.
Ok, it's TMPGenc DVD Author, of course
And yes, that Play button works as Play All one on the main menu.
My question was (again), maybe it's supposed to work this way ?
Of course, I can get rid of it in several ways, but still I have to do it on
every single chapter menu, which does not soud good
The answer is- yes, it's supposed to work that way.
(And to Sakuya- the Topic Heading "TMPGenc DVD Author chapter menu problem" gives a subtle hint to the name of the authoring program).
Need one app to trim, crop, menu, chapter and author to DVD... in batch!
By bhershey in forum Authoring (DVD)Replies: 4Last Post: 24th Mar 2011, 13:06 -
TMPGEnc DVD Author 3 (Chapter Split In two)
By GeorgeD123 in forum Authoring (DVD)Replies: 2Last Post: 13th May 2010, 21:44 -
Tmpgenc DVD Author 1.6 How Do I Move a Chapter One Page Over
By sneed in forum Authoring (DVD)Replies: 14Last Post: 3rd Nov 2007, 08:47 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43
