  1. I think this was mentioned before, but not really answered...
    1st Problem:
    When I try to extract the AC3 audio stream from a VIDEO_TS folder, then I get this error message: VIDEO_TS: Unknown format
    This is somewhat weird, cause beforehand ffmpegX could successfully create an AVI with AC3 sound from that VIDEO_TS folder. 8)
    2nd Problem:
    I managed to extract the AC3 stream with another tool and now I want to mux it with my above mentioned AVI. ffmpegX starts doing so but never finishes the task. (I know this can take time, but not several hours on a dual G5 :P )
    cheers,
    hauke
  2. 1/ ffmpeg engine does not handle VIDEO_TS format as input.
    2/ Are you using Mux as.. AVI (1 audio track), or Mux as.. AVI+audio (2 audio tracks)?
  3. 1. let me guess: ffmpeg doesn't, but mencoder does?
    but mecoder doesn't support that passthrough option...
    so theres no way to extact the AC3 sound with ffmpegX then?
    2. as AVI +audio.
    as mentioned, the avi has already one audiotrack and i want to add another.
  4. Yes, but the source has to be VOB instead of VIDEO_TS.
    AVI+audio need a lot of time to complete. Possibly you should wait some more.
  5. Yes, you're right. It took around 4:40 to finish. Unfortunately the sound was not in sync.
    Perhaps the AC3 was not correctly extracted by yadeX...
