Hi i winder if you can help me.
I downloaded a film i believe it is avi, When i run it through avi codec. its says the video codec is svcd/dvd and the audio codec is mpeg-1
i then ran the file through TMPGEnc 3.0 XPress and conceted it into mpeg2 and set the size of the file to 3.7gb and the file converted and can watch it through ok on my pc.
i then tried burning the converted file to DVD using ulead dvd movie factory 2. it created the vob files and data structure and began to burn to the disc. about 3-5% the disc ejected and up popped a message saying the following.
"Failed to recor the data to the disc.
ERROR: DVDR-INC-SPTI-2A-02-06-09-00
(93006:1:0)
Anyone know what this is and how to combat it as ive just wasted a discwell about 4 now lol
Hello,
Well first thing would be to try a rewritable disc that you could erase. Also look for a firmware update for your dvd drive. You could also tell Ulead to make the folder only and burn the video_ts folder with another program to see if that helps.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
firmware burning problem
By weedhopper in forum DVD & Blu-ray PlayersReplies: 6Last Post: 1st Aug 2010, 12:34 -
BDMV burning problem
By rickoshay in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jun 2010, 05:48 -
Problem with burning.
By googoodolls in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Dec 2009, 07:20 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39
