  1. Since the latest update this proggy blow all the other apps away without a doubt....... Encoded movies are brilliant, with no pixelations.
    Live Life 2 The Fullest, Live The Life U Luv & Luv The Life U Live!
  2. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    goody for you, pleased to hear you like it and took your time to tell us all about it, as you did with your DVDShrink grievances. So has DVDcopy2 been dropped now?
    if anyone replies with DVDShrink is better then you have fallen for it and advise you take a browse through these threads
    https://www.videohelp.com/forum/viewtopic.php?t=235960
    https://www.videohelp.com/forum/viewtopic.php?p=1015338#1015338
    p.s. DVDShrink users don't even bother replying saying DVDShrink is better to this as we have seen it all before and we all know where it goes
  3. 1'st of all I didn't try to convince any 1 here to switch from the use of shrink.
    2'nd I may have said I thought DVDCOPY was best @ the time I made the post cause it was so. The key word in my posting is since the latest (update) IC8 is best, never had pixelation problems and the pic quality is better now, It can't be beat.
    Apr 2003
    Largo, FL
    Good luck if you ever need to use another program on the IC8 created files. Personally I would never consider a program "the best" when it creates a disk that can't be opened by most other programs.
  5. Originally Posted by BobK
    Point well taken, however CCE, TMPGEnC, as well as Rebuilder is limited apps as well yet most folks here swear by the quality of such proggys.
  6. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    limited in what way?, I follow what BobK mentions as IC isn't very reliable at creating compliant DVD files if you start removing stuff. It normally shows when using a fussy standalone or trying to load it into another DVD application
    I don't think Rebuilder is limited by this though and the other two don't produce DVD files, unless you are talking about TMPGEnc DVD Author which doesn't backup DVD's (or does it?) but does produce DVD files
