  1. Guest
    Guest
    I dont know what happened,but my browser font has inncreased in size.I cant find any size options under fonts in the tool section. Where can I change this.
    also,has any one heard of this.I forget how to do it but would like to.
    Say you open folder window and u have like fifty files .U can select all of these somehow and just name the first one all the others will be named the same but with a sequential # at the end.
  2. Banned
    Sep 2004
    Inner Circle of Thought
    View----text size.
  3. Guest
    Guest
  4. Banned
    Sep 2004
    Did you get it fixed?
  5. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    If you have a wheel mouse, hold down the CTRL key and roll the wheel back and forth. That increases / decreases font size and may have been how you accidently changed it.
  6. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    qoute:
    on windows folder, press Ctrl on your keyboard don't release
    left click on the files you want to rename
    (you can also use Edit / Select All if you want to select all file on a folder)
    when you highlighted all the files you want to rename, right click (RIGHT) on any of the highlighted file, then choose Rename...type the Filename for the multiple files
    click Yes on the message...your done
    hacking the Net using typewriter :D
