  1. im using dvd shrink and alcohol 120 to burn and copy. I started haveing trouble with my back up getting to the closing disk part and then i get a burn error. i have tried a few different disk , right now im using maxell dvd-r. I tried an dvd rw and it works and as soon as i put in a dvd-r it say burn error.
    i tried an phillips dvd-r and some will burn and some will not. I have not had any trouble out of my amxell disk untill now so i dont know if the burners going out or a bad lot of disk. I was baking up man on fire. any ideal would help alot thanks
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    You could check your manufacturers website for a firmware upgrade for the drive.
    Kevin
  3. i used the same drive for over a year , with the updated filmware
  4. is there any programs to check disk for errors
  5. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    DVDInfo Pro
    Jan 2003
    Best Coast, Canada
    Also, try burning at lower speed. I often burn 4x disks at 2.4x for better-quality-burns.
    Jan 2003
    India
    If you are a smoker you need to clean your burner once in a while with commercially available tools.
