Hi all,
Just having a bit of trouble with DIKO. Im trying to convert a xVid > DVD, although the file it generates is a .mpv file.
Ive made sure the "Create DVD image" box is checked, and have tried twice, but it still just spits out the .mpv file.
Anyone got any ideas?
DIKO is relatively new and the occasional bug is to be expected. I played with that program several times and recall something similar happening once. Could've been corrupt data in the audio that caused BeSweet to choke, who knows? I was just messing around and didn't try very hard to get to the bottom of it. Anyway, I just used ffmpegGUI to convert the audio to ac3, renamed the mpv to m2v and authored with the elementary streams. Worked fine. Have you tried to view the mpv file? If it plays okay, you might try the above method.
Good luck.
P.S.: you could also try re-installing DIKO, and take special care you set it up properly. Also, it's usually a good idea to scan an AVI for bad frames first in VirtualDub before doing a conversion, just in case you haven't been.Pull! Bang! Darn!
Encoding with diko
By djgazzabhoy in forum Authoring (DVD)Replies: 2Last Post: 13th Dec 2010, 05:49 -
Question about DIKO
By Belfour in forum Authoring (DVD)Replies: 7Last Post: 6th Aug 2008, 01:27 -
Error using diko
By thecrock in forum Video ConversionReplies: 4Last Post: 24th Apr 2008, 17:55 -
How to make DIKO files into DVDFiles ?
By Locutus666 in forum Authoring (DVD)Replies: 17Last Post: 4th Nov 2007, 04:31 -
DIKO for dvd burning
By wristar in forum Authoring (DVD)Replies: 1Last Post: 29th Oct 2007, 14:41
