Hi People!
Im tryin to use a guide (Add a menu to a DVD without re-authoring, using DVD-Lab Pro) of this site (https://www.videohelp.com/forum/viewtopic.php?t=220758) and im having problems. Anyone can help me, please?
I followed without any problems till this part:
Finally open the VIDEO_TS.IFO file
Click on VMGM_PGCI_UT table, then on the +, then on the first PGC
Modify the second command to 20 04 00 00 00 00 00 02 (DVD-Lab makes by default the Title key on the remote to jump to the root menu but we don't have one).
Then click on the VMG_PTT_SRPT table and modify the number of chapters to the correct one.
Finally click on the VMG_VTS_ATRT table and modify the number of audio and subtitle streams to the correct one, then modify the attributes by double-clicking on each in the top view (the VMG overview).
I know that must be too much newbee questions, but i just ask that someone explain some parts of above text.
" Click on VMGM_PGCI_UT table, then on the +, then on the first PGC
Modify the second command to 20 04 00 00 00 00 00 02 (DVD-Lab makes by default the Title key on the remote to jump to the root menu but we don't have one). "
Later at same text Petar says :
" However, in the latest Beta I noticed that DVD-Lab doesn't do this anymore. Won't hurt to include this command anyway just in case (make it the first one instead of the second one)."
Q1: 1st or 2nd command, anyway 1st or 2nd FROM WHAT EXACTLY? from PRE- COMANDS of first PGC of VMGM_PGCI_UT table?
" Finally click on the VMG_VTS_ATRT table and modify the number of audio and subtitle streams to the correct one",
Q2: in VMG_VTS_ATRT there are "audio and subtitle streams" of the MENU and "audio and subtitle streams" of the TITLE. Petar refers to "audio and subtitle streams" of the TITLE, is it right?
"then modify the attributes by double-clicking on each in the top view (the VMG overview). "
Q3: In IFOEDIT i just can see attributes at the bottom view not at top view, what im doin wrong?
Q4: The attributes, i get them exaclty FROM WHERE? I copied them from VM SCRIPT window of Object Commands of DVD LAB, am i right?
Q5: when i edit the attributes, in the audio attributes the availble digits in the IFOEDIT match correctly with digits of VM SCRIPT window of Object Commands of DVD LAB. but the sub-picture attributes in IFOEDIT are shorter than in DVD LAB. the last 2 pairs of numbers just dont enter. am i in the right place?
Thanks in advance for all that read/reply this post
Results 1 to 1 of 1
I need IFOedit for Mac
By bryceguy in forum MacReplies: 7Last Post: 14th Dec 2011, 12:45 -
2 small questions about authoring with IFOEDIT
By i_j_2009 in forum Authoring (DVD)Replies: 2Last Post: 30th Sep 2010, 11:15 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 01:42
