Hi,
I've captured video from most types of video tape, but I had someone ask me to put about 10 of those 8cm DVDs that are recorded inside the videocamera itself on a conventional DVD-R or 2
Anybody know, what I'll find when I explore the 8cm DVD on my PC. I've never had anything to do with them in the past.
Will there be an MPG2 file, or an AVI or finalised mixture of VOB files etc etc. I believe that the disks have been finalised by the owner of the camera.
Is it possible to actual capture from these cameras in realtime by the firewire port
I think the camera is a Sony DCRDVD201 , and that's all I know
I want to maintain as high a quality as possible if indeed it can be done.
So, if you've done this before, please enlighten me on what my options are
Cheers
Hello,
You should either find vobs or that vr video stuff. If it's vobs just do the normal dvd copying and editing. If it's vr you'll have to do some forum searching because I'm not familiar with that type.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Camcorder Video to Several DVDs with menus
By vanillafrozen in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2011, 05:12 -
Newbie question RE: burning DVDs from HD camcorder
By lcinva in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 12th Sep 2011, 09:53 -
How do I make an edited compilation of several different commercial DVDs?
By WileE in forum EditingReplies: 8Last Post: 27th Nov 2010, 20:33 -
Burning DVDs from JVC (GZ-MG142EK)camcorder
By gillbeans in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 09:02 -
Help burning multiple 8cm DVD+RW from Camcorder to 12cmDVD+RW
By WOWSY in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jul 2007, 14:48
