Which program can I use to just take out extras and menus, but won't compress the movie? I've tried to search this but I couldn't phrase right, and got 12,000 or so related topics all the ones ichecked (about 100) took out extras but also compressed. I don't want to compress?
Results 1 to 10 of 10
What We Do In Life, Echoes In Eternity....
Yes, my vote goes to DVDShrink, reauthor mode.
/Mats -
DVDshrink, Love that program for LOTs of stuff!
Any chance though of a great program like that where you can select what to keep and what to delete and still keep menu's? Even if it don't shrink, afte backup we could use DVDsrink on those files if needed then.
Sort of like the check boxes for langauge and subs. You can choose what to keep and what to lose, would be nice to be able to uncheck the comercails and other stuff but still have menu's and extras!
Dvdshrink is good at showing what each thing is in a preview so you know if you want it, but no way to uncheck it and lose the trash is there? So only other option seems to be Movie only.
What's the best guide for IFoedit for this? Looked at the program haven't used it yet. -
Originally Posted by overloaded_ideIf in doubt, Google it.
Thanks, might be about what I was hoping for, will look at it.
I actually been trying to find a way to replace a Vob with one of my own also, sort of like that, just make about 12 super shorts a few megs large and replace the un-wanted 60-266 meg vobs for comercails. Just adjusting the names to match. No luck yet, they do play but then the dvd messes up after. Never burned one yet, just tested files on Pc. -
DVDShrink has the ability to replace a title (commercial, extra...) with a still image, so you can keep the original structure, but allocate as much space as possible fro the main title.
/Mats -
VOBBlanker ??
I tried that program, looks interesting once I figure it out. I did one test backup I played with several times. Have to learn it better though.
I did get rid of the long comercails but I never got rid of the FBI and such or the setup stuff for tunning the surround sound speakers!
I also had several black stills flashing at me a few times where the avoided content used to be. I did get good results consdering it was the first try!!
I general, I did get to the main menu and then actual movie in like only 3 seconds instead of the 20minutes of comercails that disk had
Everything seemed to work fine, I left all movie extra's, I just wanted to dump the stuff that had nothing to do with the movie, like Lion King Comercails!!!
Also I will have to look at the change to stills option in DVDshrink again too. Using the 2 programs together may work well. I actually want to remove, not change them, but in some cases I want to add my own stills.
Converting to a still, then swapping that with one of my own may work well!
This DVD actually advertised TV shows on it!!! I don't pay $20 so I can be forced to watch advertisements for TV which I do not even watch!!! I have not had a working system to watch TV for about 8 years now!!! Thought about getting a dish system of some type a few times, but always change my mind and don't. -
Originally Posted by Denvers Dawgs
So if you have a movie (just the movie) which exceeds the size of the blank, you still need to compress. Unless you wish to cut it and put on to multiple blanks.It's time to kick some butts, and presto ( if you know what I mean ) -
@overloaded_ide
Either titlesetblanker or vobblanker will do it. However, Vobblanker currently does not process menu VOB, so if your FBI warning was in a menu VOB (or in the VGM), then vobblanker won't do it.
Titlesetblanker will do it in all cases (make sure you check the appropriate place, depending on where the warnings are).
One of the things that vobblanker does that titlesetblanker does not is blank individual PGC, or even individual cells. That's necessary when the unwanted stuff lies in the same titleset as your movie (or stuff you want to keep) or a required menu...
See this thread
http://forum.doom9.org/showthread.php?s=&threadid=82724
jean
need a free program to Compress MP4 files
By angryassdrummer in forum Video Streaming DownloadingReplies: 16Last Post: 2nd Jul 2012, 05:51 -
What program can compress videos to 700mb?
By Jmart285 in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jun 2010, 12:22 -
Remove extras and keep the original menus
By jujuandhuhu in forum DVD RippingReplies: 4Last Post: 7th Mar 2008, 08:55 -
keeping the menus, removing the extras
By Belfour in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2007, 09:27 -
whats a good program to use to convert/compress to h264
By cowboysroy31 in forum Video ConversionReplies: 1Last Post: 20th Jun 2007, 18:28
