I have used Cuttermaran for the last week and have liked it a lot. Today I tried to use it and when I loaded my file and tried to play it, it gave an error and said no audio codec installed. The file is from my dvd recorder. It is in ac-3 format. This type of file worked the other times I tried. Any suggestions?
I can't be the only person who has had this problem. Does anybody have any suggestions?
I have used this software and i never had this kind of problem, try to install the software again.
Hope this helps you. -
I have tried reinstalling both cuttermaran and .net framework. I love the way this program work (when it was working). I can't figure out why it worked for a while then didn't. Any Ideas?
Have you tried using MPEG2Schnitt? I like it better than Cuttermaran, although Cuttermaran sometimes cuts files that MPEG2Schnitt won't, and vice-versa..
I have tried MPEG2Schnitt. I don't really like the interface as well as cuttermaran. If I can't get my problem fixed, I may have to use it.
Cuttermaran 1.70 synch issue
By cjbrown80 in forum EditingReplies: 5Last Post: 30th Aug 2011, 11:16 -
Cuttermaran doesn't execute
By Somebody2 in forum EditingReplies: 0Last Post: 7th Oct 2010, 15:23 -
Cuttermaran Encoding Problem
By SkyIs2Blue in forum EditingReplies: 4Last Post: 9th Jun 2010, 15:15 -
Cuttermaran JTI error
By tonyp2 in forum EditingReplies: 0Last Post: 16th Sep 2009, 10:28 -
Cuttermaran with Vista?
By Rychezilla in forum EditingReplies: 7Last Post: 18th Apr 2008, 17:16
