  1. I have been using the same optiwrite dual format burner with the same Memorex DVD+RW media, same software and all the sudden I can not read the DVD burned by the computer. Same media (even same spindle of ones that work). Nothing has changed that I am aware of.
    Any idea? Any way to compare a working DVD against one that doesn't?
  2. all memorex RW media is cheap. It's been doing this since they started making 4x cd-rw's, and still does it on my dvd+rw's. Try to do a full erase with nero, it may or may not work...usually quick erase causes problems with memorex. Unless your problem is completely different, and has nothing to do with erasing. In either case, memorex is bad! BAD, I SAY!
    -Yar, matey!-
