  1. I am trying to install Fireburner on my computer.When I go to install it says "Another version of this program is already installed.Installation of this version cannot continue".I have deleted everything on my computer and out of registry that is fireburner related,but this keeps coming up.Is there any other files under another name related to this program that is causing this.Any suggestions would be appreciated
    tks
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi popgun2k,
    How did you clean out your registry? Manually or a tool?
    If you didn't use it, try Registry Mechanic (latest version: 3.0). You can download a trial from http://www.download.com.
    I'm not saying it is your registry, but that'd be my first place - clear it out properly.
    Good luck...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Daamon
    Cleaned registry with this program,but it did not help.Still says same thing.
    tks for reply
  4. Member daamon's Avatar
    Melbourne, Oz
    Hi,
    On a couple of occasions, I've posted queries of this nature at http://computercops.biz/ and have got prompt and helpful replies.
    That's the best I can do I'm afraid...
    Good luck.
    Carpe diem.
  5. No luck guys tried everything suggested,but its still there
    tks for replies
