I would like to author a DVD. My starting point for the main content is a media file with the following attributes according to G-spot:
452mb, 45:23 length
VIDEO = MPEG-1
352x240 1.47:1
29.97 FPS
AUDIO = MPEG-1 Layer 2
44.1kHz, 224kb/s
I have read the very informative guide at:
http://dvd-hq.info/Compression.html
I would like to use TMPGenc to encode this into an MPEG-2 file to use in a dvd, and my question is about the most useful settings.
VIDEO:
The goal is quality, not speed. I can turn this 452mb file into 4GB worth of DVD if I want to, but should I? I want the higher resolution of MPEG-2 (704x480) but will encoding at 8000kb/s VBR improve the viewing experience or am I just wasting data?
The other question is about the size. Starting with 352x240, that should become 704x480 as the finished product, right? Does that mean that it is best to set the size to 704x480 in TMPGEnc even though it automatically sets it at 720x480? Will the other mpegs on my dvd also need to be at 704x480 for me to put the DVD together in DVD architect?
Thanks so much for any help you can give. This is a pet project that I am hopiong to do a good job on.
Results 1 to 10 of 10
It is best not to re-encode your video, you cannot make it any better...in fact you will make it worse by increasing the resolution. Your video already is DVD compatible. The audio needs to be resampled to 48 Hz, TMPGEnc DVD Author will do that for you as well as authoring and burning. I suggest you give it a try or look up some other VCD to DVD guides under format conversion in the green "all guides" section to your left.
"Art is making something out of nothing and selling it." - Frank Zappa -
thanks for the quick response. the audio part i have a pretty good handle on, and thanks for the idea on using VCD standard. i have considered that but want to add some other content that will make the total size too large for a single VCD. i though i might as well fill up the dvd with data once i decided the project would be too large to fit on a VCD.
what are your thoughts as far as the size issues? -
Originally Posted by NewHomebrew"Art is making something out of nothing and selling it." - Frank Zappa
right, both 352x240 and 360x240 are VCD-compliant, but will they both coexist on the same vcd? if not, what is the recommended way of turning 352x240 into 360x240?
1. Demux the file to elementary streams (you can do this in TMPGENC).
2. Then re-encode the audio portion to .ac3 using besweet or ffmpeggui.
3. Author with DVD authoring software of your own choosing. I know that TMPGenc DVD Author accepts MPEG1 VCD res files.
**NOTE** you could re-encode the video to mpeg2 but keep the res the same.Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing-- -
Originally Posted by ZippyP
Drop your file into TMPGEnc DVD Author and let it upsample the audio for you while it is authoring. Leave everything else as is.
Very, very painless procedure, that.If in doubt, Google it. -
Originally Posted by CaseyComb
I had a similar decision to make earlier this week. I created the following script to test the principle. My specific project was to convert a low resolution PAL DVD to NTSC. I had the whole 4.7GB available for the one and a quarter hour video so the decision was open. I know that all videos are not checkerboard patterns but I believe that this helped me to make my decision - i.e.go for the higher resolution. Since your project is NTSC to NTSC - the difference may be negligible
Code:#First create a checkerboard clip that is a 1/4 of the final size + 4 pixels wider topa = BlankClip(length=3000, width=72, height=92,pixel_type="RGB32",fps=25, color=$000000) bota = BlankClip(length=3000, width=72, height=92,pixel_type="RGB32",fps=25, color=$FFFFFF) topa = AssumeFieldbased(topa).Separatefields().SelectEven() bota = AssumeFieldbased(bota).Separatefields().SelectOdd() Interleave(bota,topa) lines = Weave() turnright(lines) b = SeparateFields() topb = SelectEven(b) botb = SelectOdd(b) botb = AddBorders(botb,1,0,1,0) botb = Crop(botb,0,0,-2,-0) Interleave(topb,botb) check= Weave() #Clip the additional 4 pixels Crop(check,4,0,0,0) #Up the size by a factor 4 PointResize(352,288) ConvertToYUY2() #De-comment only one of the following and feed into Vitualdub to analyze #BicubicResize(352,240,0,0.75) #Lanczos4Resize(352,240) #LanczosResize(352,240) #BicubicResize(704,480,0,0.75) #Lanczos4Resize(704,480) #LanczosResize(704,480)
Specific Panasonic VCR buying advice needed
By Sainsbo_McManus in forum RestorationReplies: 8Last Post: 28th Nov 2011, 19:30 -
Ripping DVD or Converting VOB files at a specific Bitrate - Help a NOOB.
By Corellian Corvette in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 20:09 -
Noob, hoping to get some advice...setting up media center pc.
By KidCastro in forum Media Center PC / MediaCentersReplies: 7Last Post: 12th May 2010, 09:30 -
Possible to encode a Premiere Pro video in DivX format? (total noob seeks advice)
By metathran in forum EditingReplies: 24Last Post: 30th Jan 2010, 20:55 -
Need specific advice on MacBook-based video editing before buying a laptop!
By psychotronicfilms in forum MacReplies: 12Last Post: 28th Feb 2008, 16:47
