I have a 6,8 gig hdtv .avi file (1280x720) which I tried to split in order to fit on 2 dvds. But no avi splitter seem to be able to handle hdtv, they keep saying wrong file, format unknown etc. Does anybody know a program that cand handle this? Thank you
what type of avi file is it (codec type)? vdub can split them ..
unless it is drm protected that is ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
windows media file with ac3 ?
that may be a problem
Yes, it's an avi made with wmc9 and ac3 filter. HDTV, probably originally a .ts file captured with a hi-def sat receiver or a pc card. I downoaded it as it is, with the info above. It looks like virtual dub can't handle it either, or I don't know what to do. But I think it doesn't accept files larger than 2 gig.
a .ts file is mpeg2 -- transport stream
Capture HDTV and Convert to approx. 350 MB avi file
By gapstar in forum Capturing and VCRReplies: 4Last Post: 29th Mar 2010, 00:18 -
Will this work? cable tv w/o STB split to HDTV and VCR with input via AV
By rcholden in forum Newbie / General discussionsReplies: 0Last Post: 28th Oct 2009, 17:19 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
split one file avi in two
By Jomapil in forum Newbie / General discussionsReplies: 4Last Post: 8th Mar 2008, 14:13 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
