  1. Hi all...
    I`d like to know where can I find a (preference for open source) software to convert bmp files to one mpeg file. And I`m also looking for an mpeg "decomposer" - mpeg to bmp (or any other picture format, but not yuv). Can you help me?
    thanks in advance
    . Leo
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    mpeg to bmp you can do in virtualdubMOD and tmpgenc
    bmp to mpeg you can do in a number of apps - but directly you would have to pay for the encoder ..
    but you can frame serve from virtualdub or avisynth to freeware mpeg encoders
  3. Thanks a lot!!!
    I`ve just tested virtualdubMOD and it will be really helpfull. By the way, it is open source isn`t it? Do you where can I find the source code? It didn`t came with the file I`ve downloaded, and the readme does not mention a thing...
    . Leo
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    Originally Posted by leo77
    Thanks a lot!!!
    http://prdownloads.sourceforge.net/virtualdubmod/
    is source code location
    it is very difficult to compile i seem to recall
  5. Member vhelp's Avatar
    Mar 2001
    New York
    You can also code your util tool (c++ or Delphi) with the right components.
    I'm not C++ pro, but Delphi I am. But, I lack the memory where I put some
    source code to:
    * - Open AVI files
    * - Open MPEG-2 files (see doom9, under development (old archives))
    * - haven't done any MPEG - to - BMP though.
    But, it would be easy (I think) to quickly rig up a tiny app to open MPEG files
    and save them to BMP files (real quick too) but I can't help you here.
    If you go into the Programming section on this forum, (or doom9) you might
    get some suggestions if you post their.
    That's about all I can think of to help or suggest to you. Good luck.
    -vhelp
