I was wondering what the best settings are to capture tv.
I have a WinTV-GO that I use to capture tv.
I am using PowerVCR 2 to capture, but there are so many settings to use that I have no idea what to pick! I would like to watch it at full screen too and not take up tons of gigs on my harddrive or DVD
So what settings should I use or do you suggest another program to capture tv?
Hello,
You could use your lowest dvd quality setting if your JUST watching TV and not recording. That would give you a decent picture but not waste a lot of temp file space. If your capturing for dvd you could use the highest setting and shrink it after you author with dvdshrink. If you don't want to lose quality determine the length you need and choose one of the lower dvd settings so it will fit without shrinking. Each situation is different so there's no real ABSOLUTE best setting.
Win TV Go use bt8xxx.
Capture the higher you can for best results.La Linea by Osvaldo Cavandoli
Are my capture settings ok ?
By smartel in forum Capturing and VCRReplies: 107Last Post: 29th Mar 2012, 10:13 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Virtualdub settings to capture DV
By magillagorilla in forum Capturing and VCRReplies: 12Last Post: 11th May 2010, 13:42 -
Capture Settings for Divix
By Nosey249 in forum Capturing and VCRReplies: 2Last Post: 13th Feb 2010, 17:45 -
If VirtualDub capture, which one and what settings?
By tluxon in forum Capturing and VCRReplies: 3Last Post: 20th Jan 2009, 20:05
