  1. I keep reading about avisynth to tempeg but is there a way to rencode with out converting to avi. I tied the Infoedit patch but it didn't work in my dvd player (denon dvd 2900). For some odd reason the dvd shift down about 1/4 of the screen. When i put a pal disc in there. So i tired the Infoedit way but no luck so i am looking for a way to convert pal to ntsc the easiest and best way...
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Sorry but converting the frame rates is NOT EASY. This list of guides will help:
    https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=&howtoselect...or+List+Guides
    Search the forum for PAL to NTSC and you'll find a TON of posts about it. It's going to take work.
    Kevin
    P.S. I know I tried the patch method but it kept having audio synch issues.
