I have captured some VHS video that has poor audio on it. I've captured it using Pinnacle in avi format. Converted this to mp2 using Canopus Procoder and then encoded this to mpeg using TMPGenc. I'd like to edit the audio on it using a wave editor (or like) to try to improve it. TMPGenc will only export audio as an mp2 file which nothing I've got will edit. I have converted this to a wav file but now Nero Wave Editor is acting up and giving this error "An error occured while trying to open the wave output device". Anyone got any nice easy ideas how to edit this damn audio??? Can it be editted in mp2 format? If not whats anotehr good wave editor besides Nero?
Try mp3directcut. Don't forget to download the mpglib.dll on the bottom of the homepage. You'll need it for the mp2 files. This will allow you to edit your files without the need for recompression, and any losses. There's likely to be a slight 'click' though unless you cut on a silent bit.
Nothing if not difficult -
Tmpgenc MPEG Encoder can output the audio of the file in WAV format.
Try File --> Output To File --> WAVE File.
You can then chose the audio codec, where you should select PCM Uncompressed. This will be accepted by any audio editor.
However, if you plan to cut portions of the audio, you will end up with a useless audio track that won't sync with the video.
If you want to modify volume or clean up noise, then it's ok.
Once you are done with editing the audio, use the MPEG tools in Tmpgenc Encoder (File -->MPEG Tools) to demux the original MPG file to video and audio, delete the original audio, re-encode the new edited audio with Tmpgenc as a single audio file to MPEG 1 layer II and multiplex it with the video stream to get a new MPG file.
(Sounds more complicated than it really is. If the file is large, it will be boring as well to wait for the demux and re-mux to complete.)The more I learn, the more I come to realize how little it is I know.
How to mux M2V and MP2 ?
By aussie74 in forum Authoring (DVD)Replies: 5Last Post: 19th Mar 2012, 07:17 -
Extract .m2v and .mp2 files
By geohei in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2010, 12:42 -
Merging MPA video and MP2 audio files
By makf in forum Newbie / General discussionsReplies: 2Last Post: 7th Jul 2009, 19:13 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 15:10 -
Why MP2? Then why failure?
By Gripweed in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 22nd Jun 2007, 05:32
