Well I had a brain Fa*t the other day. I was going to make a DVD copy of my parents 8mm movies DVD that I had just put togeather. As I started the copy I remembered I still had the DVD-RW in the drive. The DVD-RW had all the raw data MPEG files on it. Is there any way to retrieve any of the files? When I put the DVD in the drive it says the disk is empty but in fact I think only about 8-10% may have been overwritten. I have looked several places for a "fix" but nothing about DVD data recovery. Would anyone know of a program to recover the data???
Thanks in advance.
Len
there are a good number of data recovery. i have used Powerquest Lost and found, and Ontrack EZ recovery to retrieve data, but as i remember this was for HDD. i never attempted to revover from an optical disk that was partially erased.
a friend mentioned this company to me, and you may want to take a look:
http://www.cdroller.com/Be satisfied, the day is yours. If i have to explain, you would'nt understand. -
Also just plain 'ol DVDDecrypter has worked for me in the past as well.
Well I gave all three of your ideas a try and none of them worked (darn). I want to THANK all that made suggestions. I have to admit I think the files have gone to the big bit bucket in the sky.
THANKS again,
Len
HD data recovery of family videos
By Arrriba in forum ComputerReplies: 3Last Post: 9th Jul 2009, 23:27 -
data recovery
By janefield in forum ComputerReplies: 10Last Post: 18th Feb 2009, 23:45 -
Data Recovery - any way to not get ripped off?
By sdsumike619 in forum ComputerReplies: 16Last Post: 6th Dec 2008, 02:10 -
Important data dissapearing from Cd. Need Recovery !
By cyflyer in forum MediaReplies: 10Last Post: 14th Oct 2007, 10:54 -
Any CD data recovery freeware??
By foton in forum Newbie / General discussionsReplies: 1Last Post: 30th Jul 2007, 15:44
