XP sp2 won't keep the windows firewall running after I restart my computer. I already am using Zonealarm and hooked up to a router. Maybe that's why. Also, I ordered some shoes from K-Swiss's website and when fininshed they said they logged my IP address. It looked like my real IP address but I thought running my computer through a router masked my IP address so nobody could obtain the real IP address am I wrong here?
Results 1 to 10 of 10
SP2 will not run 2 software firewalls, and one will be disabled. as to you IP address being logged, was it your routers IP, or your system on your network?
you do not want to use 2 software firewalls. as to your router, you may want to look over settings within it, and see if there has been any changes, or problems. if there is a problem, you can look to the manufacturer's site for known problems, and fixes.Be satisfied, the day is yours. If i have to explain, you would'nt understand. -
Ok, thanks I will just keep one software firewall running. As for my IP being logged, it wasn't the IP my router is putting out so I am inclined to think it was my true IP address. I went into network settings and the router's IP address is the one listed so I know nothing has changed.
The ip address is the address of your router.
The computers use different addresses.
For example 192.168.15.30 -
No. SP2 allows for multiple software firewalls. Not allSP2 will not run 2 software firewalls
current firewalls will co-run however. Sygate works
fine. -
But the question is Why would you want to run 2 software firewalls?Originally Posted by offline
They would just fight each other for control. -
bazooka,
I'm surprised you have not come across this during
network security. Multiple fire walled systems are designed
to react to different levels of threat. As a simple example, I
use PeerGuardian to protect against known commercial
abusers of tcp/ip traffic, pest patrol corporate against active-x and
militant script, sygate for general i/o protection, XP SP2 for o/s
and a private firmware/software countermeasure TSR that I'm testing.
ZoneAlarm with VPN and a router alone can't protect open ports. If you have any open
ports to the net, or even a public lan/wan, you should not rely
on the o/s to protect itself - this is what you are doing if you are
running just ZoneAlarm. -
Normally I would agree with you, but I recommend a hardware firewall plus a software firewall, not two software firewalls.Originally Posted by offline
That is my hardware firewall - just uses a TSR to connect, not a background service.private firmware/software countermeasure
I agree with you - most people just need a VPN router setup and
a software firewall. I'm worried about keyloggers and RT's
which is why I go the extra mile.
PS: PeerGardian is worth looking at if you are doing p2p and
don't want to be ID'd.
Need Firewall for windows 8
By mysts in forum ComputerReplies: 8Last Post: 25th Nov 2012, 18:31 -
Which Firewall To Use In Windows 7?
By V Bot in forum ComputerReplies: 23Last Post: 30th May 2011, 22:34 -
Is QT Alternative 1.81 and 3.x compatable with Windows Vista SP2?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 8th Feb 2010, 00:02 -
Windows XP SP2 capturing problem
By superdud1400 in forum Capturing and VCRReplies: 4Last Post: 23rd Jun 2008, 00:50 -
Are there any Free Firewall Programs better than Windows XP Pro ?
By ofield1 in forum ComputerReplies: 8Last Post: 18th Feb 2008, 07:14
