Hello,
i want to edit existing dvd menu and change some buttons on it. Is it possible? If so, how? What software to use? Is there any web page about that?
Tnx for anything...
Fitik
how do you want to change the buttons?
you can remove the highlights and change the command using Menuedit, DVDRemake and PGCEdit(I think)
To edit the actual image takes a little more effort but it's also possible. You can either edit an original still menu using a paint program, or you can rebuild it best you can using DVDLAB or similar and then replace that menu into the VOB's but you may lose the original 'feel' of the menu
the only thing you couldn't really do with ease was add a button to the original Menu as the subpicture will not allow the new button to be highlighted
. I've finally managed to do it and even with dual aspect menu's that have 2 subpics and the process is not that hard
Does anyone know how to, or if it is possible to rip just the subpicture of a menu. What I want to do is rework the menu and later use it in DVDMaestro. I can rip just the menu itself as an image or video, but I don't know how to rip the "highlights" for the buttons.
Editing the commands of the buttons on the DVD menu?
By rone in forum Authoring (DVD)Replies: 24Last Post: 18th Jun 2011, 05:35 -
Active Buttons on DVD Menu
By dartmanx in forum Authoring (DVD)Replies: 1Last Post: 22nd Jun 2009, 05:53 -
DVD Menu Image Buttons With Video Background
By sk8_aholic in forum Authoring (DVD)Replies: 3Last Post: 20th Nov 2008, 00:01 -
PLEASE HELP - DVD Menu Buttons - I dont even know where to start...
By sk8_aholic in forum Authoring (DVD)Replies: 6Last Post: 10th Sep 2008, 01:40 -
Can background from DVD Menu be extracted from buttons/subpic?
By Scav2003 in forum Authoring (DVD)Replies: 4Last Post: 23rd Oct 2007, 18:54
