    Jan 2003
    central NJ
    I've been using PowerDVD to play a DVD and then clicking on the Frame Capture button to capture frames to BMP files.
    I have to be pretty quick with the mouse clicks to get just the right frame. I'd really like a program where I see the individual frames and select the ones to capture to JPG files.
    Is there software that does what I want?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Powerdvd can let you step frame. It's one of the buttons on the player. It will frame advance one at a time and you can still snap a pic.
    Kevin
    Jan 2003
    Canada
    absolutely right!!!
    dont let the vids runs , press pause then navigate with the frame button.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    virtualdubmod does a better job at this -
    i am just down on powerdvd as i find it not as good quality as some other codecs and can not handle some types of mpeg files ..
