I have Sony MiniDV camcorder TRV25. It picks a lot of wind noise when I tape outdoor. I just want to know if there is any free or low cost software that will remove or reduce the wind noise when I edit the file. I have Screenblast Movie Studio software for editing.
Thanks for your help.
Stretch a condom over the mic to reduce or eliminate wind noise. I know it sounds wierd, but pros do it. Also consider a standard wind screen, you know the little afro thingy.
As for your tapes already recorded, I am afraid there isn't much you can do for it. I am not aware of any free tools that remove wind noise. You might try a band stop filter that basically blocks the low frequencies (where most of the wind noise will be).
Darryl
Determining audio cassette noise reduction encoding type?
By jbd5010 in forum AudioReplies: 5Last Post: 28th Feb 2012, 22:18 -
Any Suggestions for Noise Reduction Software
By blaqlion22 in forum AudioReplies: 13Last Post: 16th Jun 2009, 08:08 -
VHS Audio Noise Reduction / Rumble
By Vidd in forum AudioReplies: 4Last Post: 1st Mar 2009, 16:47 -
Video Files Using Noise Reduction Software
By Teac23 in forum AudioReplies: 0Last Post: 31st Dec 2008, 07:27 -
Noise reduction
By Geevim in forum RestorationReplies: 3Last Post: 5th Nov 2007, 07:23
