Ritek GO3 -R, anyone burning 4x?
Can't find my GO4 disks right now, they weren't printable and I haven't been using them for awhile. But I know I have some!
I was burning printables at 4x for awhile, then my NEC2500 dropped back to 2x burns. Then made 3 coasters in a row, however the Toshiba 2X drive I have was burning disks from same spindle just fine, so it was not disk related I am sure.
In trying to get the NEC burning again I have moved it from system to system and it burned great at 2X! DVDINFO speed test though is only getting up to about 4-5X reads. It's now back in the original system, same results. Running in PIO mode only device on that Ide Cable.
After running DVDinfo on the disks, my printables show as GO3. I forget what they were supposed to be, or if I even cared when I bought these spindles, but I was thinking 4X and GO4.
I am sure they were burning at 4X before. I also upgraded to Herries 1.07 firmware while trying to get the bugs out. Dropback to 2X was before upgrading firmware though.
Anyone burning GO3 at 4X? That is a 2x rated disk is it not? I checked both spindles I have here and some I have burned already and all report GO3. So was I just lucky to begin with and my drive burned at 4X on a 2X disk for awhile and is Now working correctly burning it at 2X, or have I still got a drive problem? Since the only coasters in these 2 spindles were on this drive and all in a row (on drive, not spindle) and the spindles worked fine on the Toshiba 2X at that time I have ruled out a bad disks.
If I am burning the correct speed at 2X for the disks with the NEC 2500 A then I am satisfied untill I find my known GO4 disks and see what they burn at. I can always order some 8X for the NEC and burn the 2X on the Toshiba.
Watch out for the grimlins! I just had a wave of problems roll through 4 PCs within about 1 1/2 weeks. All different problems, all at once, and 3 had no changes made and are not connected to the net at all! Was really wierd the way it happened!
Results 1 to 1 of 1
NEC ND-4550A Problem
By drakster in forum DVD & Blu-ray RecordersReplies: 3Last Post: 3rd Jul 2010, 13:25 -
Problem with burning.
By googoodolls in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Dec 2009, 07:20 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
NEC 4571A problem
By rmorrison1 in forum DVD & Blu-ray WritersReplies: 18Last Post: 1st Jul 2007, 13:35 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39
