http://www.johnisme.com/avi.shtml
I used the above guide and converted a 25fps xvid .avi to 23.fps and it works fine on my comp, audio sync and all. but when i convert using Cinema Craft Encoder (much faster than Tmpgenc) and burn it, it skips...well...it goes.....1,2,3,4,4,1,3,4,4 (frame 1,frame 2....etc). does this have to do with 3:2? not sure what to do. Can the "decimate" option help? how so, and how does this work? also, whats the difference between "Source rate adjustment" and "frame rate conversion" in VirtualDub. Thanks for help and sorry if this has been discussed before, i have searched with no luck, link me if you can find something.
Im using VirtualDub-MPEG2 1.5.10
Did you run pulldown on your 23.997 fps video. NTSC dvd video has to be 29.97 fps.
Use pulldown.exe with gui on 23.976 mpv files that you create with cce,tmpgenc has templates for this type of file which applies pulldown during encoding.
I am having the same issue, I have a perfectly good PAL dvd that i want to convert to NTSC so it will work on my NTSC player,, not sure how to go about doing it successfully!
1) Please don't threadjack, start a new topic.Originally Posted by sdsumike619
2) Read some guides, there are several on framerate conversion
/moderator bugster
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Just a Thanks pal to ntsc guide.
By Fat Tony in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2010, 14:03 -
Guide wrong? "Converting a PAL DVD to NTSC using CCE"
By OliverGrey in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 02:47 -
CCE guide for PAL to NTSC conversion
By alexs_eu in forum Video ConversionReplies: 9Last Post: 21st Jun 2008, 08:41 -
Need for NTSC DVD to PAL DVD guide
By Lure in forum Newbie / General discussionsReplies: 59Last Post: 17th Jan 2008, 15:43
