You've got yourself a good little money-spinner then, haven't you ?
I don't exactly agree with doing this from a moral point of view, but that's just meI would suggest that you should be reading all the guides and FAQs instead of using the free advice you're getting here to turn a profit , unless you're prepared the offer us a cut
Anyway, I've said my piece![]()
Results 31 to 35 of 35
If in doubt, Google it.
i don't do it for profit, the money is good though for buying the CDs and PC Hardware ...im more on the knowledge i will be getting from the experience
advice and opinion from an experienced video enthusiast like you is i think much better than all the guides and FAQs...
hacking the Net using typewriter :D -
How about a cut then ?Originally Posted by d_unbeliever
Anyway, back on topic, I think it all depends on whether you want to get hands dirty or not. As I mentioned, Eazy VCD is just a GUI for VStrip, Besweet, DVD2AVI and TMPGEnc but it is very simple to use and does not require much tweaking to obtain IMO excellent results. Most options are automatically selected for you and then it is just a preference thing as to whether you change any of them. It does VCD, XVCD, SVCD & XSVCD and can output to an MPEG or to a bin/cue file. It will retain the chapter points if you output to bin/cue also.
If you want absolute control over everything that goes on, then ZippyP.'s suggestion is the way to go IMO. Smartripper or DVD Decrypter to rip to HD, DVD2AVI to demux audio and frameserve video and then TMPGEnc to re-encode video while muxing audio back in. I would look at the guide here for some pointers on making XVCDs. You would need to tweak some of the settings for a spec VCD or SVCD/XSVCD.If in doubt, Google it. -
thanks a lot, that was very informative and helpful jimmalenko...
i'll be thinking of the cut
http://www.digitalfaq.com/capture/interlace.htmOriginally Posted by d_unbelieverWant my help? Ask here! (not via PM!)
Virtual Dub converted files poor quality.
By stark88 in forum Video ConversionReplies: 4Last Post: 8th May 2011, 23:39 -
VCD Audio converted to DVD
By Monkeyboy13 in forum Video ConversionReplies: 1Last Post: 23rd Jun 2010, 13:45 -
converted a divx 1.1 gb. dvd was only 2.6 gb and poor quality. why is this
By sabre76 in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 3rd Jul 2009, 16:15 -
converted AVI to VCD, but playback is too fast
By LWC in forum Authoring (VCD/SVCD)Replies: 4Last Post: 21st Nov 2008, 22:55 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
