ok i have a buttload of codecs on my pc,,i got to messing around with ffdshow and seen all the configuring in it,,anyway can i get rid of all the others and just use that,,or should i leave well enough alone??
I've always lived by the motto "if it isn't broke don't fix it". Unless your experiencing problems I'd leave them alone.
Is there anyway to download every codec that's ever needed just to have them all?
I have systems NOT connected to the net I want to view some various downloaded vids (demo's, public domain, and other LEGAL stuff)
Although they all worked fine on the system they were downloaded to, about half will not work after moving to the system I want to use them on. Mostly all codec needed problems and I will NOT connect that system to the Net for any reason. I do however have a system here on the home network I could save all the codecs on if I could then let the systems grab what they needed from that as they do from the net.
Most of the time of course the popup box gives no info other than something like conection cannot be compleated for codec download.
And what the heck is an ASF file? It works, but what is it? And is there a guide to convert it. I'll look later, but as long as I was posting thought I'd ask.
CODECs
By channelk in forum Capturing and VCRReplies: 5Last Post: 3rd Feb 2011, 21:34 -
what codecs do I need?
By johnsees in forum Newbie / General discussionsReplies: 19Last Post: 23rd Jul 2010, 08:53 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52
