I own a norcent dp 300 and absoluty loves it. it play everything i throw at it. unfortunately they're discontinue and i am searching for another cheap player for my room. any recommendation.
Computer Spec:
winxp pro, 2.4ghz, 768mb ram, 100gb -
Apex 1130... It plays everything I throw at it aswell... Never had a single problem! The only thing that is better is my new DVP642...
I have a dp-300 as well.
I absolutely love it. Mp3z on dvd = no problem.
I am kicking by arse for not buying a second one.
Heck, it was only 80 bucks canadian 18 months ago.
I'll frak out when it dies.
kiki -
I have 3 Citizen clones of the "Golden" DP 300 and they are well worth the price I paid. More expensive then the Norcent , but hey they are the "Golden" versions that can be mod'd to the hilt.
Many of the newer DVD players do the same functions as the DP300 but most can not be hack/mod'd like the "Golden" DP300 tho. You can try the the DVD players from LG, Samsung or most of the ones made in China or Korea, they seem to support most modes.
Looking for a portable dvd Player or similar device.
By AntCoe in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Oct 2011, 16:54 -
Norcent DVD Player DP315
By John Hellmann in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2009, 14:09 -
4:3 to Letterbox (or Something Similar)
By christopheramos in forum Authoring (DVD)Replies: 2Last Post: 23rd Aug 2008, 03:57 -
Norcent DVD player, ask's for language problems...
By MagikLair in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Jul 2008, 15:32 -
Problem with Norcent DVD Player, Tray keeps open/closing, tray disc error
By daveshostack in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Feb 2008, 12:41
