Hello
I am after a simple, free program to make dvd copies of my home videos.
Here's what I do.
I've got a dvd recorder which has the dv input. I transfer my home videos from my dv camera direct to my dvd recorder and trnsfer to dvd.
I would like to make copies of that burned dvd. I know I can make copy of that dvd by using another dvd player hooked up to the dvd recorder.
I too have a dvd burner on my pc. I read about dvdshrink and it seems like what I need. Simple and straight forward. I do not intend to copy and retail dvd (movies etc) just my home made videos and I do not intend to do any authoring. There are so many software out there it's mind boggling.
Will dvdshrink be simple enough for my simple needs?
Generally just copying a non-commercial DVD can be done with most any burner program. The 'Tools' section to the left has a few free ones that may suit your needs. https://www.videohelp.com/tools?s=16#16
You should probably mention the make and model of your DVD recorder in case someone here knows of any problems with copying the video fliles made by that machine. -
The dvd recorder is the LiteOn LVW5005.
I have Nero. Can I use Nero and how to copy dvd?
Thanks -
I use Nero for that all the time. Just go to the DVD menu and select DVD copy.
Do I need to copy files in my dvd to the hard drive first then point nero to a directory a burn?Originally Posted by redwudz
need help with something simple
By HandsomePete in forum DVD RippingReplies: 6Last Post: 4th Dec 2011, 03:40 -
Simple task, not so simple (rip/quicksync)
By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 20:57 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 23:38 -
Can we keep it simple?
By AlSat in forum DVD RippingReplies: 14Last Post: 26th Jan 2009, 15:46 -
Creating simple "movies" with simple graphics?
By uniks in forum Newbie / General discussionsReplies: 11Last Post: 24th Mar 2008, 02:25
