  1. im using dvdshrink 3.2 to backup the punisher.
    i use no compression on menus.
    highest compression on extras.
    still image on unrefered material.
    removed all audio except 5.1 english
    i always get an oversized ISO 4.43 GB.
    what do i do?
  2. Member Grimey's Avatar
    May 2004
    Canada Eh?
    shrink the shrunken ISO.
  3. Using still image is a bad idea. It can take up hundreds of megs of your disc. Try using Vob Blanker to just replace all the junk you don't want with tiny files and you will free up more space for movie.
  4. Originally Posted by Grimey
    Ditto.
  5. Banned
    Oct 2003
    Americas
    Not familiar with DVDShrink, but check if you can change the default DVD disc size (by a small number) in software options/prefs. Looks like the assumed DVD size is too big.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Why are you not compressing the menus ?
    Is the main title set to Automatic compression ?
    Don't use still images, use custom image and create a black bitmap to use instead.
    If your main title is set to automatic compression, it will make it fit unless it needs to compress it down less than around 50%, in which case you have a major problem anyway.
    Basically, it it won't fit, you are doing something wrong.
    Read my blog here.
