Hey guys! I have a avi file that has dts audio that I want to convert to dvd but I ususally work with ac3 audio. How do i change the header on the dts file once I've extracted it with virtualdub?
or am I doing this wrong? I cant figure out what to extension to use when I save the file with vdubb.
I'd like to know this as well.
AC3 and DTS audio from AVI's are not DVD compatible.
You can simply use AC3Machine to transcode AC3 audio, so it will become DVD compatible, but what do you use for DTS audio ? -
convert it to wav and re-encode it
Hypercube Transcoder"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 07:06
