  1. I am only able to put up to 10 min on a DVD.
    I am using the sonic MyDVD to make my videos. http://www.sonic.com/products/mydvd/mydvd/features.asp
    I have them converted to mpeg2 formats. I am using mp3 audio tracks as background music also. nothing i am using by any means will take up the 5 gig of space on the DVD disk. My video's are no larger than 200 kb.
    A few things I think it is. (with my limited knowledge)
    1. DVD burner sucks. brand is NU dvdrw ddw-081
    2. software to burn to DVD sucks. see above link
    3. I am using the wrong format. (but I want the quality I am getting now)
    4. making the buttons on the dvd is taking up the space.
    there is a error that I dont have atm (but I will get at a later time) that says something to the effect of there is not enough space on dvd. But I know that is not the case. when I convert the dvd versions to windows media format they are 11,000kb, 7,000kb and 8,500kb. In there mpeg2 format I would think that they would fit on a DVD easily.
    Please help me. I am tired of ruining my DVD's and have spent about 30 dollars on failed attemps.
    anyother info you may need that I have missed please let me know and I will get it.
  2. First thing, buy some DVD RW discs. Use those for test burns.
    Second, what are the actual file sizes after they have been converted to MPEG2?
  3. Member daamon's Avatar
    Melbourne, Oz
    Hi Natecon,
    Two things:
    1. It might be (guessing here) that your MP3 audio is encoded with a variable bitrate (VBR) instead of constant bitrate (CBR) - I've seen this referred to as a common reason why encodes are longer than expected. Not sure how you'd tell though. GSpot? AVICodec?
    Try using something like VirtualDub to extract / convert the MP3 to a WAV and use that in the DVD audio instead.
    2. Buy a re-writeable DVD-/+RW - no more coasters!
    Good luck...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
