  1. Using Dvdshrink along with Copytodvd I have been having problems with the movie freezing with about half hour left to go with it playing in my standalone and also my computer the movie was burned on. Not sure why, haven't had this problem before and I'm still using the same type of media. I've even tried using different record speeds. One thing that I might question is the upgrade to windows xp, can't remember if I had this problem before changing operating systems.
    Anyone have these kinds of problems?
    Aug 2002
    cleveland, oh
    Does the file play from the HD.
    If so you have media problems.
  3. It sure does, without any problems.
  4. Is that the only thing that can be wrong?
  5. I to have the same problems. I am using DVD+R and Nero to burn after DVDshrink. Hasn't happened on all of my burns.
  6. I had a similar problem, with movies freezing when reaching about 90 minutes.
    I use NERO on Windows XP and TY DVD+R media.
    My problem turned out to be NERO. I upgraded it to the latest version, and the problem was solved.
    Good Luck!
