I am attempting to capture relatively noisy VHS on an ATI TV-Wonder. The source is not horrible and does not jump around or anything, but when I capture, parts of the video that I capture looks horrible (sections are jumping around and the color gets screwed up). It only does this in parts of the video though. I have captured off of good VHS many times with no problems. Any suggestions?
to correct that you need a TBC to stabailize the video. cost from $200-$5000+.
Wrong, video stabalizers can be found for about 20$ US. About 40 Canadian or something.
I had this same problem. I went to RadioShack and bought one of those
gold-plated composite video cables and it solved my problem; incredulous, I
switched back to the old cable and the jumpiness returned, switched to the
new cable and the picture was stable.
So, you might want to give this a try before you spend big money on expensive
hardware.
I have gold plated Audio & Video lines from the VCR to my capture card. (They are from Radio Shack too). Pier8, where can you get video stabilizers? Thanks,
BTW, this is not a copy protected tape I am trying to capture. It is just a high generation copy of a television show from the 80s. I can see slight jumpiness in the area an area (on the the tape) but when I capture, that area REALLY jumps around.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 10:36 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 23:16 -
Uncompressed vs DV capture for noisy videos
By telefunken in forum Capturing and VCRReplies: 2Last Post: 6th Mar 2009, 06:33 -
Noisy VHS workflow. AVS+MVBOB+MVDenoise+Seesaw+H264 = sigh!
By koopak in forum EditingReplies: 2Last Post: 23rd Aug 2008, 16:29
