Okay, since last year, I usualy convert my movies to MPG-1 spec and burn 3 or 4 movies on a single DVD using TMPGEnc DVD Author but the quality is not great... since blank DVD media are so cheap now, what I want to to is put 2 movies per DVD using MPG-2 full DVD specs..
I figure that by lowering the birate to do a MPG-2 file around 2167Mb,
leaving space for the authoring, and yes, I know that I can use the Birate Calculator...
My question is: what's the lowest birate I can use and not lose to much quality? is there a bottom line birate not to cross? because if the loss of quality is too great, I will stay with MPG-1 files for my common movies and with XDVD for my "must keep" video's...
Thanks all
NickPick
Results 1 to 11 of 11
Hello,
This might be a place to
https://www.videohelp.com/guides.php?guideid=646&howtoselect=6;57#646tart:
I've heard you can squeeze a lot onto a disc if you use 3500 as your video bitrate. I believe 2000 is the spec for svcd quality. I think you shouldn't go lower than that.
you may want to try using 1/2 D1 at 900 min , 5500 max , 2820 as average
that will get you 3 hours , 20 minutes"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hey, thanks a lot yoda313...
Stupid of me, I was just checking the What is DVD? page and I just saw the bitrates for VCD and SVCD.... and since the "usual" bitrate for DVD is around ~5000kbps, I will try around 2000kbps and 3000kbps...
Since the bitrate for MPG-1 VCD is just 1150kbps, I think the quality is going to be okay or at least 200% better
Thanks again, I'v learn something today
NickPick -
Yeah, I will have to play around depending of the size of my movies..Originally Posted by BJ_M
Thanks, time to start experimenting
NickPick -
No! VCD is 352x240, DVD is usually 720x480. So DVD has four times as many bits to encode, requiring (as an oversimplification) four times the bit rate to get the same quality. Full D1 (720x480) MPEG 2 at 2000 kbps usually looks like crap. If you cut the video size down to half D1 (352x480) it will look a better and still be fully compatible with the DVD spec. And be sure to encode with a variable bitrate if you're going that low.Originally Posted by nickpick37
Ahhhhhhhh, its very good to know
So a half-D1 with a variable bitrate would look definitively better than a VCD MPG-1 mpg?
fewww, I learn a lot tonight
As long as the bitrate isn't too low. 2000 kbps (even as the average bitrate in a variable bitrate file) is pretty low. Just try it and see what you think...Originally Posted by nickpick37
that is what i said already here https://www.videohelp.com/forum/viewtopic.php?p=1042853#1042853"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I have done a bunch of 2 movies per DVD with a bitrate of around 2500kbps(depending on length) at 720x480. The results were really good.
But these movies were not action films with a lot of motion, they were chick flick type crap like Sweet Home Alabama. Now you know why I put 2 per DVD.
I used VBR with TMPGEnc of 200min, ~2500avg, 5500max.
I think you will be quite pleased with the results.
2 movies on one dvd
By hellbringer in forum Newbie / General discussionsReplies: 5Last Post: 6th Nov 2009, 20:45 -
900min in 1 DVD? Several hours/DVD? Multiple movies or tv-series/DVD?
By edvashas in forum Video ConversionReplies: 17Last Post: 29th Sep 2009, 04:16 -
Getting movies onto a DVD
By rodeman in forum MacReplies: 3Last Post: 25th Jan 2009, 18:54 -
How many movies in a DVD?
By kkleo99 in forum Authoring (DVD)Replies: 2Last Post: 13th Feb 2008, 05:33 -
1h40min movies became 50min movies after conversion
By oediv in forum ffmpegX general discussionReplies: 1Last Post: 31st Jul 2007, 15:13
