I have been going round in circles for a while now, was hoping somebody might be able to help me out.
Ok...I have a few divx movies that i want to convert to ksdvd (using diko) but the movies are running at 30fps - diko wont take them (unless its gold)
I tried dvd2svcd (both converting it to PAL and leaving it at NTSC) both come out with the same problem, the audio sounds like its in slow-mo.
I tried openingthe divx file in virtual dub mod then extracting the audio (it was mp3 - then adding it to the stream list) then going to the "Video Tab" > Frame Rate. Here i tried both "Adjust Source Frame Rate - 25.000 and the next set of options with is "Frame Rate Conversion" - Convert to 25.000....both dont work for me!
Does anybody know a way i can change the FPS on this divx movie from 30FPS to say 25FPS? I prefer using diko as it allows me to put a few divx movies on a dvdr. I have tried searching for a answer and come up with nothing!
Any idea's?Thanks in advance!!!!!
Fracmo
(I tried the guides on this site, most were for (s)vcd - but the others were for frameserving - dont have a clue about that. The http://www.johnisme.com/avi.shtml one looked good but when using besweet it wouldnt actually do anything, just come up with a notepad document & no "output" file)
