what does frameserve mean, is it (for eg) using virtualdub to input video into tmpgenc or am i on the wrong track here,![]()
The older versions of virtualdub (under 1.5x) have an excellent guide under the help menu/content/advanced topics/frameserving which explains it's use with vdub.
Well done. That's how I learned it a long time ago. -
I do not doubt thatt Avery gave a good answer to it in vdub 1.5, but for lazy SOBs like myself, the short answer is that before you can encode a video that has been compressed (DVDs are compressed with MPEG2 for example) you need to decompress it into an uncompressed state. One way to do this is to convert the whole video to an uncompressed video stream then compress with your codec of choice. The downside of this is that it requires what is scientifically known as "a whole lotta space" to do.
The other option is to just uncompress a few frames at a time as you encode the video stream. Then discard the uncompressed frames after you have encoded them into your new video stream. This is frameserving.
-Suntan -
Suntan
Somehow and don't ask me why but I understood thatI do not doubt thatt Avery gave a good answer to it in vdub 1.5, but for lazy SOBs like myself, the short answer is that before you can encode a video that has been compressed (DVDs are compressed with MPEG2 for example) you need to decompress it into an uncompressed state. One way to do this is to convert the whole video to an uncompressed video stream then compress with your codec of choice. The downside of this is that it requires what is scientifically known as "a whole lotta space" to do.
I wonder if efiste2 did?
I still like the explanation in vdub 1.4x better. :P
@ efiste2,
Another good answer here:
http://www.avisynth.org/
The Devil`s always.....in the Details!
Where can I download Frameserve ?
By DuBsTaR in forum Newbie / General discussionsReplies: 19Last Post: 9th Dec 2011, 18:47 -
Can't Frameserve to Tmpgenc
By BonnieW88 in forum Video ConversionReplies: 1Last Post: 30th Aug 2009, 23:40 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 06:24 -
Frameserve on MacOS??
By Maxwellbest in forum MacReplies: 5Last Post: 4th Oct 2008, 16:34 -
How do I DeInterlace and Frameserve?
By rocky12 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jul 2008, 21:50
