  1. When i install netFrame,it makes the welcome screen (the one that has your name on it) to appear. If i uninstall it goes away. Does anyone know how to disable this? I am the only one that uses this computer and really find it annoying.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    what is netFrame?
  3. I guess what i wanted to say was .Net Framework 1.1
    thanks
  4. Mod Neophyte redwudz's Avatar
    USA
    Do a search for Net 1.0. It doesn't do that. I had the same problem and this worked well for me. The name of the file is 'dotnetfx.exe'. It doesn't require the login.
    EDIT: Here's the MS address for 1.0. http://www.microsoft.com/downloads/details.aspx?FamilyID=d7158dee-a83f-4e21-b05a-009d0...displaylang=en
  5. Get hold of a copy of TweakUI for whichever operating system you are using,
    To be quite honest it's a utility i wouldn't be without and is always the first thing i install after all my drivers are on a system,
    With that you can disable logon get rid of ballooon tips alter the time the menu takes to appear and the list goes on and on.
  6. Thanks for both suggestions...I will give it a try....
