  1. welp, last night they were ok today all I get is missing codec, no id number and it wont play in wmp, it will in quicktime, but that doesnt help me because I cant convert it to mpeg due to the program that converts says the same thing. not sure what to do.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    A couple of tips:
    Fill in your computer profile.
    Mention what type of file you are trying to play.
    Mention what codec you think it uses.
    Mention the program you are using to convert it.
    If in doubt, Google it.
  3. or you could go here: Codepack.com scroll down a little and download it this solved problems I had.
  4. nothing has helped, yet I can still use quicktime to view it, but it looks pixelated. any suggesitons ?
  5. Yeah what he says....
    Originally Posted by jimmalenko
    A couple of tips:
    Now go do these things and if completed correctly, I'm sure there will be members here who will be happy to help......
    makntraks
    In the theater of the mind...
    It's always good to know where the exits are...
  6. what type of file is it?? mpg? wmv? avi?
    try gspot to identify the file properly
  7. sorry for leaving that out. its an AVI, it used to say windows media file audio/video, but now just says video clip, and that I'm missing some codec, i have no idea what codec its talking about. Ive run gspot and some other stuff, and they cant figure out what codec is either, the one that I do think it is called ccdvsd/YY or something close to that. any suggesitons are appreciated
