i dont know if this is possible, but im trying to take a song from a dvd. how can i extract the audio and then edit it so i end up with the song i want? if so, what is a good program to do it.
thanks
Try my guide here. Follow this guide down until the part that starts with "Go to the Stream Processing tab, and tick Enable stream processing if it is not already ticked...." and replace it with:
In the Streams section, click the none button – this will untick all streams. Tick only the stream you require. Make sure that "Demux to Extra file" is selected for the stream you have ticked.If in doubt, Google it. -
Cut songs from music DVD
By Pitorasilo in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2010, 22:19 -
Can anyone advise me how to copy karaoke dvd songs
By BILLION in forum Authoring (DVD)Replies: 1Last Post: 8th Aug 2010, 17:02 -
I have a DVD-R that I burned 1200 songs on, my DVD player only can read 600
By frieday in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2010, 04:31 -
will songs on a dvd play on a CD system
By tammasarath in forum AudioReplies: 24Last Post: 27th May 2009, 21:27 -
How to rip separate songs from a music dvd...
By lordhutt in forum DVD RippingReplies: 4Last Post: 31st Dec 2008, 13:50
