Results 1 to 14 of 14
    Apr 2004
    hey, i was wondering, is it possible to make a VCD of a video that is 829 mb, and is 93 min long? i already have the file converted, and i dont want a disc of just 10-13 min. thanks
    Apr 2002
    The State of Frustration
    You can quite easily make an XVCD of a video by lowering the bit rate until it fits on CD-R.
    Hello.
  3. Member pchan's Avatar
    Mar 2003
    Singapore
    You need 850mb CD-R media and your CD burner must be able to support overburn.
    EDIT:
    If you want to play your VCD on a standalone player, your bitrate must 1,150kbit/sec. This is a VCD standard. Please refer to WHAT is VCD.
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    A lower bitrate will create what is known as an XVCD, or non-standard VCD. Many people make XVCD's and have no problem playing them...of course it depends how far out of spec you go and how lenient your machine is with regards to standards. I regularly make VCD's using VBR to get as much as possible on a disk. A VCD with a slightly lower bitrate should play in most machines, it's worth a try.
    Apr 2004
    how do i do that? i mean convert it to a smaller bitrate, TMPGEnc wont let me change it
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    You could open the unlock template. It's in the folders with the other templates. I can't remember where it is right now. That should let you set all of your own settings.
    Kevin
  7. Originally Posted by pchan
    Actually I think you will find the the spec for VCD is CBR at a bit rate up to 1150kbits. So if nothing else is changed, lowering the bitrate is allowed within the VCD spec, with a corresponding loss of image quality of course.
    Apr 2004
    does anyone know of a way to do this in WinAVI? because it goes faster and, well, i kinda like it better, so, im not asking for an opinion on a converting program to use, unless its faster than TMPGEnc , im asking is there a way to do this on WinAVI?
  9. Member Cornucopia's Avatar
    Not from all that I've read. 1150--not higher, not lower. I think the idea was to conform to Single Speed CD Drive (just like Audio CD), which would always spit it out at the same rate. Consider the VideoCD's history--that makes sense. 2x was just coming out when the spec was published.
    Now, SVCD, that's a different story.
    Also, most DVD players are quite forgiving with a slightly lower bitrate. So it doesn't make too much difference.
  10. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Why not try a 90 min CD? It will hold your 829 MB mpeg no problem. Only problem is that some players might not like these "out of specs" CD-Rs...
    /Mats
  11. Originally Posted by Cornucopia
    from https://www.videohelp.com/vcd under VideoCD 1.1
    It is recommended to keep the video bit-rate under 1151929.1 bps.
    Apr 2004
    alright, well, either way, i burnt the vcd with a bit rate of 900kbits, and it works great, works fine on my dvd player, and the video isnt that bad, and the sound is great
  13. Banned
    Aug 2002
    beautiful
    Should've listen to someone who suggested to use 99min CD-R... they're only $0.50/pc and I assure you that if you won't have more than 99min59sec of data or audio on them - they'll play on almost any dvd player.
  14. Member Thomas Anderson's Avatar
    Sep 2004
    The Real World
    Instead of reducing the video bitrate a lot why not reduce the audio bitrate. The standard is 224kbps, why not use 128kbps so you don't have to decrease your video quality as much.
    Or, like some people said, use a VBR.
