I have an ATI AIW 9600 capture card running in XP with a Pentium 4 CPU and 1.5 GIG of RAM. I am also using a dedicated HD for capture. I have discovered while viewing or capturing VHS tapes I recorded using a video camera that I have some distortion along the top 20% or so of the picture. The distortion almost looks like a tracking problem and is intermittent, but is always limited to the top of the frame. This distortion does not show up when viewing the same tape via a television set, only when viewing it on the computer. Apparently the ATI card is translating any tape errors into this distortion, which does not happen when playing the tape on a VCR and viewing through the TV. Any ideas on how to fix this problem?? Is this a problem that ATI cards are more likely to produce, or is it a common problem associated with playing/capturing VHS tapes using any capture card?? In any event, I would like to figure out the best way to fix this problem as I would like to capture home-made VHS tapes and burn them onto DVD to send to family.
Thanks for the help!
Closed Thread
It sounds like the common problem with VHS tapes. Head switching noise is one explanation I have heard. As you noticed, it is in the overscan area of a TV and doesn't usually show.
You can crop it out during encoding, just make sure your video is padded out to the DVD resolution. TMPGEnc will do this. Or if in AVI format you can do it with Virtualdub.
Sorry Red but it's not overscan and does show... www.nepadigital.com/mvOriginally Posted by redwudz
BTW dzachau the mods don't like double posts.....
Do not cross-post:
https://www.videohelp.com/forum/viewtopic.php?t=237343
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Dumb question on improving video for capture from VHS tapes
By lewist57 in forum Capturing and VCRReplies: 13Last Post: 2nd Jul 2010, 12:26 -
Trying to get a good digital capture of an old VHS tape
By StrobeLightEpileptic in forum RestorationReplies: 2Last Post: 21st Nov 2009, 22:16 -
How to capture a full VHS tape?
By burrowsfan in forum Newbie / General discussionsReplies: 11Last Post: 5th Feb 2009, 18:54 -
TV/VHS tape Capture card suggestions for my pc?
By drwho in forum Capturing and VCRReplies: 5Last Post: 27th Sep 2008, 20:49
