I captured an mepg-2 with d1 and then split it into native m2v and the audio, which is pcm. I want to convert the pcm to mp2 so I can import it into mpeg2schnitt and cut out the parts I don' t want. I tried running it through BeSweet GUI but it just brings up the besweet dos window for a fraction of a second and then shows the log. The file it created is 0 kb. What can I do to convert it (other programs)?
Hi Garibaldi,
ffmpeggui does WAV/PCM to MP2. It's simple, quick and totally reliable.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Great idea! That worked great because I can convert audio right from the original mpeg! That's an interesting way of looking at it, rather than trying to convert the extracted audio. So I use demux to make the m2v file and ffmpeg gui to extract the audio from the original mpeg.PostPosted: Sep 14, 2004 20:24
Hi Garibaldi,
Converting MKV to DVD compliant file
By carlmart in forum Video ConversionReplies: 18Last Post: 15th Apr 2011, 12:51 -
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 01:46 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 16:10 -
Problem with PCM Audio track when Burning DVD
By darnhs in forum DVD RippingReplies: 7Last Post: 11th Aug 2008, 22:07 -
audio PCM to MP2 while retaining DVD menus
By navels in forum Video ConversionReplies: 2Last Post: 20th May 2007, 16:51
