I can get a a DVR from Charter Cable. It has S video out, Digital audio out and RCA audio/vidio outs. The instruction shows how to hook up a VCR.
Can I use a DVD Recorder instead of a VCR?
Any technical problems I might experience like interlacing problems?
Will the recording be as good as the original?
Which DVD recorder should I use?
I'm a newbie on this page and need some guidance from the experts. This seems like a cheaper option then buying a DVD recorder with a hard drive. I want to make a couple of copies of football games I record. Any advice will be appreciated.
Originally Posted by mustvid
1) Certainly.
2) You may encounter Macrovision, but then you'd have the same problem with a VCR.
3) It depends on a number of factors (for example: recording quality selected, your eyes, etc).
4) Can't help you there, but I'm sure someone will shortly. In the meantime, you can read the current/previous discussions to get an idea of what people are using.
Btw, welcome to the forum!
Suggest a DVR to replace the one from my cable company
By mowermanEd in forum DVD & Blu-ray RecordersReplies: 17Last Post: 25th Mar 2011, 20:32 -
DVR and Cable Box
By pepegot1 in forum DVB / IPTVReplies: 12Last Post: 27th Oct 2010, 19:33 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
Capturing Cable DVR Help
By Chala in forum Capturing and VCRReplies: 4Last Post: 6th Oct 2008, 17:53 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 07:20
