I just tried to upgrade my Real Player on a machine and got a message saying that a file is missing. I checked further and am missing this whole folder. C:\Program Files\Real\RealPlayer\rpplugins\pdge3260.dll
The items in bold are what I'm missing. I'm sure I can create a folder on my own, but can someone help me with the file. I tried installing it 4 times with the same problem. My other machines do not have RealPlayer, This machine Has Real Player, but no QuickTime. Just the way I have my computers set up. Yet they all have Windows Media Player (because it came with the OS).
The OS on this machine is NT, but it should still work. Anybody able to help or send me the file if they have it?
Results 1 to 9 of 9
Sorry Doramius. I don't have Real Player. I did a search anyways, but I don't have that file.
Why not use real alternative.
It will play the files without the tsr file. -
I've found Real Alternative doesn't play streaming audio and video. There is a streaming audio site I listen to and my Real Player isn't working. It's the only setup they have or I wouldn't use Real Player. I think it sucks.
Doramius,
this may not suit you.
I needed a way to play streaming and non streaming
real video minus the bloat that comes with realplayer.
Using a link partly hidden at the BBC website I was
able to download a Win98 version of realplayer. It installs without the usual rubblish and works just fine
with streaming video/radio. -
It's here...but you gotta look through the list -
http://www.kephyr.com/filedb/index.php?categoryBrowse=1
I use Real Alternative now, but when I used Real Player, I was able to install just the player and none of the extras that come with it.
It has to do with the settings during and after installation...and you also need to disable the player at startup and disable all the update popup reminders.
Without all that stuff, it's nice.
Real media has its advantages - it doesn't suck if you know how to use it and if the files aren't set to the crappiest/lowest bitrate/quality. -
I ended up having to talk to a support technician. He says WinNT doesn't support the newest version, but it supports one version back. So I downloaded it and it's working now. I had to wait on hold for 48 minutes. I'm at work so I just left it on speaker while I did web surfing. I'm usually not in the net at home so where else can I post whore?
Thanks All for your help. even though nobody provided any real useful information :P
RealPlayer sucks, true story.
I think VLC can handle Real media. May want to check that one out. -
I normally don't use Real Player, but it's the only streaming program I use on my NT station. NT sucks too, so I might as well keep them together. I only need it at work anyway.
Video File (Suspected Real Player)
By Keycool1 in forum Video ConversionReplies: 2Last Post: 16th Feb 2011, 20:55 -
no dvd audio in WMP or Real player.........
By tomnat in forum Software PlayingReplies: 4Last Post: 7th Feb 2008, 18:50 -
Real Player Format
By Russo in forum Newbie / General discussionsReplies: 3Last Post: 30th Nov 2007, 23:00 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 06:05 -
Real Player file downloads
By thegoose47 in forum Video ConversionReplies: 2Last Post: 10th Oct 2007, 15:47
![Computer details: Windows Server 2012 R2
(2x) 2.93 GHz Hex-Core Intel Xeon X5670
Toshiba OCZ RD400 NVMe PCI-Express 1TB card
(2x) onboard Crucial MX200 512GB SSD
60TB+ NAS storage [mixed amongst Synology 1515+ & 1815+]
144GB Registered DDR3
Plex Media Server Comp](/images/buttons/computer.gif)
