Hi first I looked in the guides and doesnt find anything. Did someone knows a program to comvert WMA file located in hard drive to MP3. Thanks
hello,
Burn a audio cdrw from the wma than rip that like any normal cd.
TMPGEnc can,you just import the WMA file to 'Audio Source' then select 'Setting'.
You will need the lame.exe codec: www.rarewares.org/mp3.html
I think Goldwave can also.
This won't work if the WMA file is encrypted(DRM). -
Nero 6 can also do this
but need the WMA plug-inhacking the Net using typewriter :D -
dbPowerAmp can do it , and it's free! Add the proper codec listed, and away you go.
http://www.dbpoweramp.com/dmc.htm
wma to mp3
By rjc7394 in forum AudioReplies: 5Last Post: 14th Sep 2010, 14:00 -
Help with MOD to mp3/wma
By Bluntz11 in forum AudioReplies: 10Last Post: 14th Apr 2009, 20:12 -
Is it possible to convert Mp3 to wma?
By t_jay17 in forum AudioReplies: 8Last Post: 17th Feb 2009, 16:32 -
Converting mp3 to wma with Vegas 6.0
By solarblast in forum AudioReplies: 2Last Post: 1st Oct 2007, 06:50 -
wma to mp3
By rjc7394 in forum AudioReplies: 0Last Post: 8th Jul 2007, 19:28
