i encode and author many dvd from avi files however i have found it very complicated to include subs. subtitle files, is there an easier way?
tools i use are vdub, canopus procoder, tmpeg author, ifoedit if i have to etc. i know i must missing something simple can anyone advise.
thanks
mike
Just one question: What format are your subtitles usually in?
Hello. -
Good. You're halfway home.Originally Posted by incar
1. Use VobSub Resynch (freeware), load the .sub file into and save as an .srt. Use SRT2SUP to save it as an .sup file.
2. Use TMPGEnc, select File=>MPEG Tools=>Simple Demultiplex and load your MPEG file here. Select RUN. When it's done, you should have an .m2v file, and an .mp2 file.
3. Change the extension on the .mp2 file to mpa.
4. Open IfoEdit, select DVD Author=>Author new DVD. use the following image to load the files you need:
I wish I had an easier way to convert the .sub to .sup, but I can't think of any at the moment. Gurus?Hello.
Rip DVD including subtitles using vlc
By skeptic_always in forum LinuxReplies: 10Last Post: 22nd Sep 2013, 22:19 -
Including subtitles in VOB2MPG
By Magna Jet Convoy in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 26th Feb 2012, 06:01 -
Burn MKV to DVD including 5.1 audio and subtitles ?
By Dinky2 in forum MacReplies: 4Last Post: 11th Jan 2012, 15:29 -
DVD to iPoD/PSP/Cell phone/PCP including subtitles using DVDFab Platinum
By Baldrick in forum User guidesReplies: 6Last Post: 14th Nov 2009, 15:09 -
DVD to PSP, whats the easiest way to do it?
By Nick1982 in forum Newbie / General discussionsReplies: 0Last Post: 8th Jul 2007, 07:45
