and back to the regularly scheduled program...
if you have Partition magic 8.1 (get the free update 8.0 to 8.1 from Powerquest (now owned by symantec--eek!). 8.1 supports the changes to NTFS that XP uses.
now with P-Magic 8.1 you can manipulate your partitions, make smaller, bigger, create new, copy, change cluster sizes, and of course drive letter assignments WITH OUT losing your data. since you will be doing this via DOS, windoze will not prevent you like disk management.
a DOS boot disk can be made in windoze, but you can make a custom floppy or create a image to make a bootable CD with the files to manipulate your partitions.
i have used PM since v3, and 8.1 on the system i am on right now with 1 WD120 and Maxtor 80 x2 (RAID0)
WD120 c:=Boot 18gb primary partition/active d:apps=logical 100gb
RAID0 e:= Otro single 156gb partition for storing ISO/mpg/avi/mp3 and audio data for multitrack recording....
C is only used for OS and some docs. all my apps/games on d: and e for files as listed above.
so the answer in short is NO DATA is lost when using partition magic, unless you delete or format a partition.
Results 31 to 34 of 34
Be satisfied, the day is yours. If i have to explain, you would'nt understand.
xxgriff,
If I don't have any partitions set up on my primary...
...can I create two on my 200gb HDD with partition magic (say a 150gb and a 50gb) and move my OS to the 50gb partition?
Kinda without having to re-install anything?
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Originally Posted by "makntraks"mantraks---- i do nt know what kind of equipment you have, but i have some good shit that i want to experiment as i can afford to. right now all the shit is much faster---boot times, load app times, mozilla firefoxe loading 6 pages on start up in seperate tabs quicker that IE with one god damn page. all is great except that my drive is now G:. i will work this out and i will perfect it. being that you have not contributed anything positive, then leave my ******* thread alone. some very nice people have guided me so well that i cane home from work at six pm, installed my second SATA drive, configured my BIOS, and had a computer running in less than ten minutes. if i do say so, thanks to xxgriff, i just performed a task that i had no knowledge on three days ago, and it worked, booted the first time.
not ******* bad if i do say so myself.
someone once told me that if you have nothing nice to say, then keep your damn mouth shut. i was, am looking for suggestions to help me implement RAID for the first time in my life. if i am lucky enough to have some spending money to experiment, isn't that what it is all about??? xxgriff helped me a great deal, and i am very thankfuf for that.
if this thread does not interest you, then stop watching it and posting on it as all you have done is been a negative source for info.
let those of us that want to play and experiment do so in peace.
go bother someone else. :evil: :evil: :evil: :evil:[/quote
i know how to rescue my data and OS-------that is not the issue. i will also figure out my drive letter problems---not a big issue.
do you need any help in recovering any data or an OS??? -
will hay, you most definetly can create a second partition and not loose anything. i have done that many times before with partition magic 8. i am gonna do what xxgriff said and get the update to 8.1 so i can play around in DOS and not loose anything. let me know if this works for you. partition magic is a real friendly easy to use progam!!!!
Crucial M4 64gb raid or no raid?
By Stealth3si in forum ComputerReplies: 7Last Post: 20th Mar 2012, 04:13 -
RAID question
By mysts in forum ComputerReplies: 5Last Post: 6th Jul 2009, 15:31 -
Raid 5 to Raid 1
By mysts in forum ComputerReplies: 4Last Post: 13th Mar 2009, 23:36 -
1TB Raid?
By CogoSWSDS in forum ComputerReplies: 8Last Post: 30th Sep 2008, 08:35 -
Is Raid 1 always this slow?
By gary11364 in forum ComputerReplies: 7Last Post: 5th Aug 2008, 21:23
